Often when I click my shutter to take a photo ,an error notice shows up on my camera screen....not allowing mew to take a photo...if I turn it off some times I'm able to continue but not all the time.
SOURCE: taking photos
Here's a little more. This problem can also be caused by dirt or sand getting into the lens worm gear. Try these in order (know some of these sound silly): 1) turn off the camera, remove the flash card and batteries, then reinsert them. 2) turn the camera on and off with the AV cable inserted, 3) moderately rap the camera with the palm of your hand, 4) gently pull or push on the lens to try to overcome the lens jam, then restart. If all the above has not worked, AND if the A4XX camera is no longer under warranty, AND if this problem did not result from the camera being dropped, here's how to fix it, and it's relatively easy: http://homepage.mac.com/jpelling/page0/page0.html By the way, don't know Justin, but he did a very nice job showing how to open the camera case and clean out the grit and sand from the camera lens drive gear. Make sure you send him an email to thank him
SOURCE: Red/White Lines On Photos and LCD
Sorry I didn't see this sooner. This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: View screen black when on & no longer takes photo's
Sounds like a dead CCD. Contact your local Canon service center.
Tom
SOURCE: "BUSY" Problem
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
I hope that helps.
SOURCE: I have my canon a470 digital camera, recently i
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
