Vacuum only works for a few minutes before the battery charge winds down
SOURCE: suction problem
check the intake hose at the bottom it may be clogged.try blowing into the long hose if you can't blow through it then you have a clog somewhere between the long hose and your intake hose at the bottom.the intake hose is the somewhat clear hose that comes up from behind the base at the bottom.you will see it on the backside
SOURCE: dirt devil purpose for pets vacuum quit working
The motor overheats from the filter being clogged underneath the canister or the canister or both are clogged-without the air flow the motor overheats and shuts off as a precautionary measure.By letting the motor cool off it will start again but will turn off shortly if the filters are not properly cleaned.Hope this helps everyone.
Rob
SOURCE: Belt keeps breaking on dirt devil 85335
check and see if the brushroll still turns easy. if it doesnt, u may need a new brushroll which can be found on ebay, or dirt devil's website
SOURCE: our dirt devil vacuum is blowing out air instead
my dirt devil is blowing out air instead of sucking up.Tried new bag.any other solution to fix
