SOURCE: i have a bunker hill
Bunker hill safes have a hand held programmer (for installers only) that will allow a "power open" on the safe. Basically it is a small unit that contains batteries to provide power to the safe. It's kind of a one-last-open tool.
Unfortunatly you will have to go to a locksmith or installer for these safes in order to have them do a power open.
If you go to a locksmith that doesn't have one of these unit s/he will offer to drill the safe or pick the lock for you.
This may be your only option if you don't have a dealer in your area.
SOURCE: Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
SOURCE: Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
SOURCE: i have a bunker hill floor safe model #91006 wont
Batteries need to be replaced. Use key override under the plastic
