I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
