SOURCE: HP 7410xi small plastic piece in print cartridge carrier broken
If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
Regards,
Bob Headrick, MS MVP Printing/Imaging
SOURCE: a piece of the plastic that holds one of the
Hello. If you have that little piece you can reattach it with some clear one minute epoxy. Just do not over do it with the epoxy so you don't end up doing more gluing that you need to do. Other wise you can order parts for your printer. Just go to the following link and order what you need directly from HP
http://h20141.www2.hp.com/hpparts/CountryChoice.aspx
Regards, Joe
PS please rate my answer. Thank you and happy holidays.
SOURCE: the ink cartridge holder plastic lock broke
If you have the quick fix --
Selleys Quick Fix GelFast setting ethyl cyanoacrylate (supa glue) based adhesive with a non-drip gel consistency which dries clear.
What materials is this product suitable for?
I or have to purchase the part
SOURCE: Re-assemble Canon Ip2000
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Kitchen and dining room tables are generally the same. Except, sometimes dining room tables are a bit larger and made out of stronger materials.
