The washer on the hot feed has gone and it is leaking. I was going to buy another hose when i was told it would be better and cost effective to only use the cold feed and let the element heat the water. I am not sure if the Aquarius 1200 plus WM65 has a heating element and which scenario is better.
According to page 8 of the manual, the unit can function as you describe but the manufacturer says to use a "Y" connection to send water pressure to both cold and hot inlets, this could mean that if you don't , the machine will not fill in the correct manner, It is better to use both hoses to each supply side and not try to be cost conscious. IT takes more time for the unit to heat the water than it does to use already hot water.
SOURCE: hot point aquarius 1100
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
