My Maytag Model DE8000 Series 01 dryer has lost heat. When set on the auto-dry cycles the dryer runs, but the timer does not count down. When set on the timed air-fluff cycle, the dryer runsand the timer counts down properly. Where do I start with the troubleshooting? I have tools and a multi-meter and know how to use them. . .
SOURCE: Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
SOURCE: Kenmore Heavy Duty 80 Series Gas Dryer won't cycle/won't heat.
if you ran this unit awhile without timer advancing,,now you blew the thermal fuse,,,re place thermal fuse and timer..
SOURCE: Maytag Performa Electric Dryer Won't Start
Replace the thermal fuse and the high limit switch.
They come as a set.
Clean the auto dry sensor with rubbing alcohol.
SOURCE: maytag dryer model LDE512 will not turn off when
The timer may be faulty.
Servicing the Timer
Most dryer timers are digital or mechanical. The timer controls
most of the operations of the dryer. For this
reason, any repairs to the timer should be made by a professional
service person. However, there are a couple of checks you can make when
you suspect the timer is faulty -- you may be able to install a new
timer yourself.
Step 1:
Unplug the dryer. To access the timer, remove the control knobs and
the panel that covers the controls. This may be a front panel, or
access may be through a panel at the back of the unit. Carefully
examine the wires that connect the timer to the other parts of the
washer. If the wires are loose or disconnected, try pushing them into
position; they usually fit into their terminals like plugs. Use
long-nosed pliers to avoid breaking the wire connections -- never pull
a wire by hand.
Step 2:
To test the timer, use a VOM set to the RX1 scale. Disconnect the power
leads to the timer and clip one probe of the VOM to each lead. The VOM
should read zero if the timer is working. Since the timer is a multiple
switch, turn it through its cycle and test each pair of terminals in
turn. The meter should read zero at all of these points. If one or more
readings are above zero, the timer is faulty and should be replaced.
Step 3:
To replace the timer, unscrew and disconnect the old one. Install a new
timer made specifically for the dryer. If there are many
wires on the timer, have a helper hold the new timer next to the old
one as you work. Disconnect the old wires one at a time, connecting
each corresponding new wire as you work, to make sure the connections
are properly made. Or, draw a diagram showing the connections before
removing the old timer. After all the wires are connected, check the
connections again for correctness and screw the timer assembly into
place.
SOURCE: Whirlpool dryer takes 2-3 cycles to dry a full load of clothes
I would check for a faulty high limit thermostat. This is a small round device mounted on a metal plate and attached to the internal ductwork. It's recommended that the thermal fuse be replaced at the same time and may come as a set from a parts supplier. I will attach a photo of a fuse/thermostat for reference. Remember to disconnect the dryer from power source before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
