Usually this is because iron/sediment has built up under the button up in the head of the housing. There is a spring that holds the button closed. If you can look up inside the head (with filter housing off) you will see a phillips head screw. Remove the screw and the spring and button come out. Clean the area thoroughly and lubricate lightly with silicone lube. Re-install and test to see if still leaking. If so you can try getting a new spring at hardware or replace the entire housing.
RJ
