SOURCE: culligan gold series 9'' water softener has a constant error code
It has been my experience that when you have made several attempts to correct the error codes as directed in the owners manual, you most likely have a defective controller.
You should contact Cuno and locate a service representative near you to see about getting the controller replaced.
sanray
SOURCE: Culligan Silver Water Softener - Continues to Run
Same problem, no answer... incredible how strong is the "culligan maffia"...
SOURCE: No salt leaving Culligan softener during regen
It sounds like your salt in your salt compartment is stuck. Poor about a couple of gallons of hot water on top of your salt and see if that will break it up and fall down to the bottom of your salt container. Then regenerate your softener after about 3 hours have gone by. You should be back in business.
SOURCE: water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
SOURCE: I have a Culligan water softener and noticed
There is a problem with the piston/seal pack assembly pack in the valve. The seals get worn or some debris gets stuck and causes softener to run to the drain. The seal pack assembly needs to be replaced. If you are handy, you can do this. It takes about 1/2 hour for a novice.
Parts are only available from Culligan.
RJ
