Picture is okay. cable is connected but i can"t get rid of the wavy lines.It is the only tv in the house with the problem. The cable company is comcast. the tv this replaced did not have the problem.same room, same connection. what can i try to get rid if the wavy lines on the 32" Haier
SOURCE: Zenith LCD Flat Screen TV just shows vertical lines of color
Press menu button on the TV if the on screen display is also distorted or no pic the TV is definetely defective. You can try unpluuging from wall for about 15 minutes and see if reset helps if not problem is either main p.c.b , LCD panel , LVDS cable or Power supply board. and would require service. most likely problem would be bad connection at or defective LVDS cable that connects main p.c.b to Panel (cheapest fix) or defective main p.c.b. If it is the panel it would probably not be worth repairing and you may want to sell as is on ebay.
SOURCE: DVD picture is crystal clear, but wavy lines when using cable
you can get a standard RF (cable) male connector to AV (the yellow,white and red colored) adapter at radio shack for a few bucks...if it is a internal connection, that will bypass it...you will just be watching cable on AV-1 or wherever you plug it in
Testimonial: "thanks! will give that a try and let you know."
SOURCE: trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
SOURCE: i have a scott tv...2 days ago an electrical storm
TUNNER BAD, YOU NEED TO CHANGE THE MAIN BOARD OR CHANGE THE TUNNER WITH AN OLD USED BOARD. MAYBE IF YOU OPEN THE TUNNER FIND A OPEN LINE NEAR COAXIAL CONNECTOR.
