20 Most Recent Sanyo DS27910 27" TV Questions & Answers
2answers
Sanyo TV Chassis Series AC5-C20 no sound
check power supply to ic,, it will be 12v from smps..may be fusable resistor has gone
2/13/2023 1:51:51 AM • Sanyo DS27910... • Answered on Feb 13, 2023
I have a Sanyo ds19350 tv. It sometimes suddenly
High voltage failure. Take off the back cover and look for the high voltage transformer. The transformer has high voltage at about 380 volts with low current, but it will give you a shock. Usually, there is a capacitor or two, hopefully, there is only one capacitor. Check the DC voltage across it - should be about 390 to 400 volts. If not, change this high voltage capacitor. Buy one bigger than the current one by three times.
11/24/2017 7:13:55 PM • Sanyo DS27910... • Answered on Nov 24, 2017
manual
How do i access the menu with no remote....stuck
On the front of the tv is a menu button. Press it and it will take you right in to fix this. Maneuver the menu using the ch up and down keys.
8/18/2011 10:04:28 PM • Sanyo DS27910... • Answered on Aug 18, 2011
I have a Sanyo DS27910
You can purchase the original remote for $20.99 base price.
http://www.replacementremotes.com/SANYO/Buy-FXRG-6450459313-TV-Remote-Control.html
6/10/2011 3:23:25 AM • Sanyo DS27910... • Answered on Jun 10, 2011
Sanyo 50 inch plasma tv turned off while i was
bulp or color wheel bad
4/12/2011 3:26:22 AM • Sanyo DS27910... • Answered on Apr 12, 2011
How do I change the input selction without the
many TV support AV after the last channel pls try last channel and go ahead you will find AV-1 THEN av-2 then channel 0 like that but i am not sure pls try
8/26/2010 5:41:02 PM • Sanyo DS27910... • Answered on Aug 26, 2010
My sanyo was working fine, then a child hit a
The TV has different inputs modes, the TV tuner being on of them, another mode(s) will accept an input from the input jack(s) on the back, front or side of your TV. Look for and source button or input button on the front of the TV, press it waiting a few seconds between each push until the picture returns.
6/19/2010 3:47:20 PM • Sanyo DS27910... • Answered on Jun 19, 2010
I have a sanyo ds27910 without a remote and can't
You must get a remote......even most universals which are in expensive will have a video or input key.......the only way!!
6/2/2010 7:26:16 PM • Sanyo DS27910... • Answered on Jun 02, 2010
Black screen and no sound....Satalite repair guys
This could be a power supply board
5/13/2010 1:57:56 AM • Sanyo DS27910... • Answered on May 13, 2010
After 5 minutes of being left on the screen turns
The video board that connected to the CRT(tv tube).Have defective componnents,discribe the problems,ask the tv shop for an estamate.$100-150 to repair,i would repair it.More than that no.
5/8/2010 6:24:33 PM • Sanyo DS27910... • Answered on May 08, 2010
Sanyo model # ds27680
cold solder in vertical ic or bad.
4/21/2010 1:57:57 PM • Sanyo DS27910... • Answered on Apr 21, 2010
The fuse is blown,what can be the problem?
Hi derrick
i`m going to help you with your tv but first;
Did you try and replace the fuse?
Sometimes the fuse will blow after a power surge or black out.
And could you give me your tv`s brand name and model number so i can assist you further ?
2/23/2010 10:14:33 PM • Sanyo DS27910... • Answered on Feb 23, 2010
Is a sanyo ds27910, purchased in 2003, a HD tv
No, it is not a High Definition (HD) TV.
10/14/2009 6:50:39 PM • Sanyo DS27910... • Answered on Oct 14, 2009
Will not come on
what is it
8/24/2009 6:22:47 PM • Sanyo DS27910... • Answered on Aug 24, 2009
Television will not stay on
hoz. out put bad
8/19/2009 4:48:18 PM • Sanyo DS27910... • Answered on Aug 19, 2009
Spiral line descending across screen
hoz. out of sny. look for cap 200/100v
8/19/2009 4:46:55 PM • Sanyo DS27910... • Answered on Aug 19, 2009
2answers
RE:Sanyo 27 " Flat Tube Set
What about a cap in the power supply for the vertical circuit? Usually found near flyback-- 2)check vertical drive signal (comes from jungle IC ).Use your scope....
8/19/2009 4:42:05 PM • Sanyo DS27910... • Answered on Aug 19, 2009
Sanyo DS27910 27" TV Logo
70 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
sanyo model r n ds27680
  • Televison & Video
