SOURCE: need a wiring diagram for sony cdx-gt41ou head
Click Sony Support to download wiring . connection manual of CDX-GT410U
SOURCE: Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
SOURCE: need wiring diagram for sony cdx-gt200
blue\white stripped= amp remote
black= ground
blue= ant
red=positive
yelow=positive 12v
white=left +
white\black striped= left -
gray= right +
gray\black striped= right -
green=left rear +
green\black striped=left right -
purple=leftr rear +
purple\black striped=right rear -
SOURCE: Need A wiring harness diagram for sony CDX-GT300
Sony head units use either a 9 pin connector, link below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
Or a 16 pin connector, link below:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
And here is a kink to your installation guide.
http://www.docs.sony.com/release/CDXGT300_Installation_Guide.pdf
And your Operating Instructions.
http://www.docs.sony.com/release/CDXGT300.pdf
SOURCE: need a wiring diagram for a sony cdx-gt08 it is
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
