The "Heap Over Flow" error indicates you are basically running out of memory to store graphics commands before a command to print data is issued.
The solution is
1) Windows Printing.
A) Ensure the printers EMULATION setting matches the printer driver uses.
B) If using the T6050 printer driver ensure you have the correct lavel of firmware. The later version of printer driver need to have the latest T6050 firmware installed in the printer.
C) Consider setting the printer EMULATION to EPSON FX then install the EPSON FX100 driver on the Windows Box
Or
Install the IBM Proprinter XL24 driver on the Windows Box and set the printer EMULATION to IBM Proprinter
Using either of these two compatible drivers will 'side step' issues caused by printer firmware / drinter driver compatibility issues as it may be difficult to obtain suitable firmware or drivers due to the age of this device.
2) If you are coding the escape commands yourself you need to check these as they are incorrect if this error is seen
Presently, there are no 4230 drivers available. Please use one of the following drivers that comes with your operating system: IBM Proprinter III XL, 3287, Epson FX, Any Dot Matrix Printer Driver. The 4247 drivers cannot be used for the 4230. Source: http://www-01.ibm.com/support/docview.wss?uid=psd1P4000381
Win 7. Swift 120D, ctz9-95.zip. Download above file. Use Swift 90 driver. Equivalent Built-in.....IBM Proprinter X24E. Prodot 810x, ctz9-95.zip. Try this file it is equivalent use Win 7 version at the site. I hope that this assisted you. Thanks for using FixYa! John Download Here
I have some problem, but now have solved 1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver. 2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form 3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6) 4. Good luck
