20 Most Recent Tally Line Matrix T6050 Printer Questions & Answers
Hi you can download all version of Tally i.e. Tally 9, Tally 8.1 and Tally 7.2 from this site http://www.apnitally.com alternatively the latest version of software i.e. Tally 9 can be downloaded from
http://www.tally.co.in
Tally Line... | Answered on Jan 01, 2019
I'm not 100% sure what you are asking here, but on that printer to navigate the menus is a bit odd. Scroll to the option you want and press the key with the '1' on it then scroll to your next option and press the key with the '2'. The next menu option uses the '3' and finally you would use the enter key to display the value for the option that you navigated to using the '1,2,3' keys.
Tally Line... | Answered on Jan 06, 2016
possibly the only place would be the manufacturer.
Tally Line... | Answered on Oct 24, 2015
adjust hammer gap
Tally Line... | Answered on Jan 10, 2015
release some gap by platen manually pull up. and calibrate hammer. for better printing
clear nvram ram first
Logic card Problem. Change Logic card
Tally Line... | Answered on May 29, 2014
Please Clearly mention your Problem?
there may be two problems in the logic card of the printer
1 .ONE OR MORE RESISTANCES R165 , R166 , R167 , R170 , R171 MAY BE DEFECTIVE..
2 . FIRMWARE MAY BE CORRUPTED , RELOAD IT.
Tally Line... | Answered on Apr 29, 2014
check wheather printer is restarting , input voltage must be 48v dc for logic card
check resistances r 165, r166 , r167 , r170 , r171 on the logic card if input voltage is ok
If u r a repair technician here are some useful steps
1. check rp1 to rp13 resistance pack ( 47 ohm and 33 ohms )
2. download firmware
3. touchup the flash and font rom (U33 , U34)
step 1 : change the panel cable
step 2 : change the control panel
step 3 : download firmware as follows :
T6306 FIRMWARE DOWNLOADING PROCEDURE
  1. Connect the printer to pc through parallel port.
  2. Press "FF + ^ + CONFIG" at the control panel and power on the printer .
  3. Panel will show "ready to download".
  4. In dos mode type "vdv3000r -pb" and enter .
  5. After completing the firmware loading printer may show NVRAM fault.
  6. Press "CLEAR"and printer will restart to finish.
replace the shuttle belt or fix insulation tape on the pulley of both shuttle motor and shuttle wheel and then refix the belt.
the problem is not mentioned exactly . By the way you can check the out put voltage +48 v DC at the output cable which is connected to logic board . If it is not there , check fuse 3.15 AMP , thermistor , IRF 840 , if u r technical and knows how to repair .
Tally Line Matrix T6050 Printer Logo
113 questions posted
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Zaid Anarwala
Zaid Anarwala
CheckitRight
CheckitRight
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tally Office Equipment & Supplies
Most Popular Question
error memory access voilation c0000005
  • Office Equipment & Supplies
