20 Most Recent Matrix Okidata Microline 320 Printer Questions & Answers
Power on then off, then unplug the unit for a few minutes. Then try it.
If this does not work post back.
Matrix Okidata... | Answered on Jul 20, 2017
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Matrix Okidata... | Answered on Mar 28, 2017
An online manual here: http://my.okidata.com/PP-ML320.nsf?opendatabase There is probably a top of form setting which needs to be checked & corrected. I assume you've checked tab/margin settings in your software & printer setup?
Matrix Okidata... | Answered on Jan 13, 2017
Here is the page to the MFRs driver page for the 320 turbo
http://my.okidata.com/PP-ML320Turbo.nsf?opendatabase
Tallon41
Matrix Okidata... | Answered on Sep 17, 2012
Hola Gabriel, puedes dar mas datos. Could you give us more info please.
Ya intentaste con los drivers originales de Okidata?
Did you already try with its original drivers? http://my.okidata.com/dsdownWeb.nsf/driverlookup/D7BFA5764F4784E98525767E00689DED?OpenDocument
Your ribbon needs to be adjusted. The printhead is not aligned with the ribbon.
Matrix Okidata... | Answered on Oct 24, 2011
sagalee bilidummaa oromoo kan biyya keessaa fii kan biyya alaa kamtu azkka gaarii dabarsa
Matrix Okidata... | Answered on Jun 23, 2011
The most current driver for this product is already included in the Windows XP Operating System. Currently there are no updated drivers available.
If the driver did not work, try to use the IBM Proprinter or Epson LQ driver.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Matrix Okidata... | Answered on Mar 16, 2011
Setting Top of Form, Forms Tear-Off ON
(Step A)
! If you turn the platen knob when the printer is turned
on, you will cause the Top of Form to mis-align. Always
turn the printer off before turning the platen knob!
1 Turn the printer ON.
2 Park the paper.
3 With paper out of the unit, (red alarm light should be on)
press SHIFT (1) and QUIET/TOF (5) to reset the current
Top of Form.
4 Press FF/LOAD (3) to load the paper.
5 Press SEL/MENU (6) to take the printer off line.
The SEL light goes out.
6 Wait until the paper moves up to the tear position, then
press and hold TEAR (4).
The paper moves to the current Top of Form.
Keep pressing and holding TEAR.
7 Press and hold SHIFT and release TEAR.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Matrix Okidata... | Answered on Jan 27, 2011
could you please tell me why my copier isn't printing the copies dark enough-could it be the ink cartilage or another problem. I don't want to order the cartilage if it is another problem. It is an older copier-PC941
Matrix Okidata... | Answered on Oct 16, 2009
check you manual, set the printer back to default. or it might be with the program your trying to print with. try print a test page using your driver. if it still the same. uninstall and reinstall it back to your computer to restore it to its default value
Matrix Okidata... | Answered on Oct 05, 2009
that was really easy man i finally found a fix :) if you need guidance feel free to email me at zulfequar  at  gmail dot com
Matrix Okidata... | Answered on Mar 31, 2009
38 questions posted
Top Matrix Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
STEVE SPAM REMOVER
Are you a Matrix Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Matrix Office Equipment & Supplies
Most Popular Question
install ibm proprinter ii in windows 7
  • Office Equipment & Supplies
