Was working fine went into the store when I came out the screen shows a computer connected to a gps unit via usb and its stuck there. tried turning on and off still no change
You will need to send the unit in for repair. There is nothing you can do at home to repair this problem.
You have to download the recovery tool for your device and reformat it.
it needs to be done by being hooked up to the computer, but it's a pretty easy process. and free!
tho when i did it, it got stuck on a rebooting loop for forever, but i tried plugging it into smarteco and updating the map, which seems to have fixed the whole thing and it's working fine now.
SOURCE: Magellan Maestro 3250 wont power
Hi, as I have been in the situtaion with many electronic devices before I know how frustraing it can be when the car charger doesn't work any more. For every one out there reading this post if this happen to you again take the car charger portion that you put in the lighter for a charge, the part the goes in will unscrew, check the fuse. 99% of the time that fuse has blown and that is the cause of the unit not getting a charge, if replacing the fuse does not work the it is a bad unit and you will have to get another gps.
SOURCE: magellan roadmate 300
I posted yesterday as a guest with the same problem and then I contacted Magellan by email from thier site...this is thier disappointing response...It took less than 24 hours though.
Thank you for contacting Magellan. This email is in response to your query
about the RoadMate 300.
Our Sincere apologies for the delay in responding your email.
I understand your mail that you are unable to download or install the
software.
We apologies to inform that NO software in Magellan support MAC
Computers/Windows Vista.
I am sorry to inform you that all Magellan units are only compatible with
Windows 2000 and Windows XP.(Household and Professional) Currently we dont
have any drivers for Windows Vista. I request you to try with a different
computer.
I am confident that the above information would help you in resolving the
issue. If you have further queries, please get back to us.
You can also contact our Technical Support at 1-800-707-9971 for further
assistance.
Regards,
Magellan Email Support.
SOURCE: magellan roadmate sd card error
I had a similar error and I fixed it. That is, as far as I know...
Here's my theory: The SD card is acting like it has an error on it. This often happens when it is removed improperly.
HERE'S HOW TO FIX IT:
IF THIS HELPED, please leave a comment indicating that it did! If it did not help, please let me know that as well.
SOURCE: Can I charge my Magellan roadmate with USB cable
It depends on the Roadmate that you have. :
- If your Roadmate has a separate plug-in port for charging your unit IN ADDITION TO a USB port, then no, your Roadmate cannot be charged using your computer via the USB cable.
- If your Roadmate only has a USB port available for charging your unit, then yes, you can charge it via your computer via USB.
However, please note, according to Magellan, charging your unit using your PC via USB can take up to 12 hours to charge vs. 4-6 hours when using the vehicle power adapter.
FYI: This is mainly due to USB constraints on pretty much all electronic devices. USB cannot carry the same amount of power to a device. It uses what is commonly known as a 'trickle' charge to recharge a device. It carries much less current than a full-blown charger (like an AC power adapter).
