Blue line is on left side about 6 to 8 inches in and is about 2 inches wide. Will appear when it wants and disappears when a black screen comes up. My son plays games mainly on this tv less than a year old.
SOURCE: RCA Scenium
I had the problem myself with my Scenium, the TV has a prblom with the circuitry and only fix is through an authorized RCA repare facility. Hope its fixed for you soon, awesome tv.
Rate plz
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
SOURCE: Black Vertical line appeared on my Daewoo Plasma
Bad connection somewhere along the bottom or top of the panel, there are boards most likely along the bottom of the screen that control vertical drawing, a connection that breaks as it is heated up sounds about right. check the connectors along the bottom. Be very careful because if you wreck em the screen is junk. The connector that will be at fault will be in direct line with the black bar.
SOURCE: my rca tv wont show the color red. it comes up
Needs to be calibrated or the red gun is out. Contact the manufacturer for technical support, they should be able to provide instructions for advanced calibration using the remote. If that doesn't work, they may be able to send someone out to replace parts (if it can't be brought in.)
SOURCE: Our 42 inch RCA LCD
It can be the power supply, main board, backlight inverter board, tose are the three areas that needed to be checked.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
