SOURCE: I need to replace the belt on my hoover fusion
Hello :
1:Unplug your Hoover vacuum. Turn the vacuum up-side-down and place the motor and vacuum portion on a counter top with the handle hanging down toward the floor. This makes it easy to work on the underside of the vacuum portion of the machine.
2:Locate the two plastic release levers near the front wheels of the vacuum. On most machines you will only need to push these levers outward with your thumbs to release the bottom panel of the vacuum. On certain older models, there are two screws that will need to be removed with a screwdriver. Once released, remove the bottom plate.
3:Locate the drive belt. Unless the belt is broken completely, it will be plainly visible. One end of the belt loops around the shaft of the vacuum's motor and the other end wraps around the vacuum's beater bar. The belt is in a modified figure 8. Use your fingers to stretch the belt slightly and remove it from the small shaft of the motor which will be almost dead center under the vacuum.
4:Remove the roller (the beater bar) that is across the front edge of the vacuum. In most models you can remove the bar by simply pushing it forward slightly and then lifting it up out of the U groove that it is held in. In some models you may need to use your screwdriver to push aside two clips that hold the bar in place.
5:Remove the belt (if attached) from the bar and then clean the bar. The bar may have hair and bits of carpet wrapped tightly around it, especially at the ends where the accumulated mess could prevent the bar from spinning freely. Use scissors or a utility knife to carefully clean off all hair and other debris. Make certain that the roller rolls smoothly and easily.
6:Place the new belt around the roller, fitting it into the groove in the middle of the bar. Replace the bar in the machine. In most models, the bar should simply drop down into the U grooves that hold it. Give the belt half a twist (like the figure 8) and then loop the free end around the shaft of the motor.
7:Replace the bottom of the vacuum and push the retaining tabs back in place with your thumbs or screw in the two screws that hold the bottom on. Turn the machine over, plug it in, and it should be working like new.
Things You'll Need: Replacement belt Screwdriver (for some models) Scissors Utility knife
Warning:
1:If your machine makes a screeching noise when you turn it on, then turn it off and unplug it immediately. Turn it over and check to see that the bar is seated properly before turning it back on again.
2:Never work on your vacuum if it is plugged in.
PLEASE RATE !
SOURCE: what belt do i need for a kenmore canister vac
I'm not familiar with the model number that you posted. But if the picture you posted is the model you have then this is the belt you need
http://vacbelts.xps.convina.com/20-5201-belt.htm
SOURCE: Kenmore cannister style. Cannot remove the
It depends on the model you have. Do you know the model number? If you need a replacement belt you can get one here:
http://www.vacbelts.com/kenmore.htm
SOURCE: I need a new hose for my Electrolux central vac
You can check ebay, they have lots of electrolux central vac hoses and you can get one with the appropriate handle to attach to your power head and wands and other attachments.
SOURCE: How do I replace a belt on a Royal M1030
go..
http://www.youtube.com/user/GoVacuums?v=meX8lgZo7DY&feature=pyv&ad=3168329782&kw=how%20to%20replace%20a%20vacuum%20belt&gclid=CL_478KwgZ8CFRAeDQod7mI1NQ
I need instruction how to instaall the belt
