I have a ZyXEL NBG334W and it worked perfectly for a few months until
last week because there where some problems with the internet provider.
(I use a bridge to connect my wifi rooter.)
Although, I was not having internet access, my wifi network was detectable.
Last night, one of my flat mates has fixed the main rooter and could
get access to internet. The problem is that now my wifi rooter does not
send any signal and my 'wifi lan' led is not on when I turn on the
rooter, as it should be.
I have tried to reset it and to reinstall it but the ip address is not accessible anymore. what should I do?
cheers,
the Funky1
SOURCE: trying to configure zyxel nbg334w router
my router was working fine until I spilt water on it :(
I opened it up and all seems well and it turns on just fine but the light for the internet just flashes now.
It doesn't play nice with my router anymore, any help?
SOURCE: Zyxel P 660R T1 does not connect to internet by PPPoE
we have the same modem. visit this site, its a step by step guide http://www.pinoydsl.net/viewtopic.php?t=3916&postdays=0&postorder=asc&start=0
SOURCE: can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
