Zyxel G-360 802.11g/b Wireless Adapter Logo
Posted on Mar 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zyxel G-360 with wpa2 network?
Zyxel G-360 doesn't work with a wpa2 wi-fi network?
Anonymous
Level 2:
New Friend:
  • Expert 137 Answers
  • Posted on Mar 26, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
137
Questions
0
Helped
35462
Points
229
1. Check you desktop the hardware is decting or not.
2. if hardware is dected then install his driver.
3. after installtion of driver please check signal of card and then try to connect with your wi - fi router.
Anonymous
Level 3:
President:
  • Master 2,992 Answers
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093045
Points
9665
According to the user guide for this card, it does support WPA2. Make sure you've followed the setup procedure for entering the required key. You might want to try upgrading the firmware if it's more recent than your version. If you have everything set up correctly and just can't get the connection working, replace the card. Hardware problems can cause strange behavior.
My iLive platinum was connected to my Wi-Fi and was working great for over 6 months, now it’s connecting to Wi-Fi but not connecting the speaker and it’s not showing that my same Wi-Fi is unsecured. What...
Sounds like your WiFi settings got changed to unsecure or you have a neighbor with the same WiFi network ID (SSID) that is confusing your iLive platinum.
Try changing the name of your WiFi network and confirm that you have WPA2 security enabled.
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
I can't get no is 9" tablet to work on WiFi. It connects and says connected but won't pull up authentication screen to sign on to network so I'm not able to fully use internet
try turning the wi fi off on the tablet and then turn the wi fi back on and try to reconnect.
you may need to set up the encryption. It could be set on WPA2 and the tablet may not cope with WPA2 may need to use WPA1 on router .
3answers
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Using my phone as mobile hotspot how do i get my network ssid.
You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
1. Go to the Home screen.
2. Select the Menu key.
3. Select Settings.
4. Select Wireless & networks.
5. Select Tethering & portable hotspot.
6. Select Portable Wi-Fi hotspot checkbox.
7. Select Portable Wi-Fi hotspot settings.
8. Select Configure Wi-Fi hotspot.
9. Input a Network SSID for your connection.
10. Select a security protocol. Options are Open andWPA2 PSK.
If you select WPA2 PSK, input a password for the connection and then select the Save button.
You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
Aug 08, 2014 • Cell Phones
Wi fi connection keeps dropping
Try changing the channel on the router.
Make sure there are no obstructions around the router.
Airflow is important as these routers do not have fans for cooling.
If possible move the router closer to the computer.
It is not necessarily a problem with the router. It could be the Network card in the computer.
What is the wpa2 key / //
Wi-Fi Protected Access (WPA) and Wi-Fi Protected Access II (WPA2) are two security protocols and security certification programs developed by the Wi-Fi Alliance to secure wireless computer networks.
You need a WPA or WPA2 key to connect your Game console wireless to the wireless accespoint.
1helpful
NETWORK IS NOT CONNECING IN wi-fi in our wireless network with WPA2 system. but its detecting the network. should i install any new software to support WPA2.
try to setup again  wireless card's driver  if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
1helpful
Xbox 360
You cannot use the netgear wi-fi adapter as the xbox 360 will not be able to detect it. I suggest buying the wi-fi adapter specifically manufactured for the xbox360
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
