The printer is showing error 00020000
SOURCE: EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
SOURCE: epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
SOURCE: have a Epson Stylus cx 9400 printer and lost the
You can get the software for free but will need access to a fairly fast internet connection. Go to the epson web site www. epson.com find the column that says "support & drivers" find your printer. download and install the drivers- you may have to download a number of the pieces that are normally ALL contained on that CD you can't find
SOURCE: Hi, On Epson stylus Pro 9600.
ORDER your printhead directly from here
http://www.alibaba.com/showroom/epson-print-head-9600.html
The
100005 is a maintenance required error! The maintenance needed is a
different printhead. Ensure that you purchase the printhead that comes
with a good return policy in case the error continues. NOTE: With
exchange of the printhead, this error normally goes away.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
