20 Most Recent Epson Stylus Pro 10000CF InkJet Printer Questions & Answers
I would go to menu and do a nozzle check, a power clean and head alignment, after you unplug the machine wait a few and then re-power.
If they do not perform try resetting the cartridges and if noting then it's due to a print head error. It needs to be replaced, send to repair.
Epson Stylus Pro... | Answered on Apr 12, 2013
Check inkcartridges.
You can snap off the cover plate carefully, under it you will see a plastic film that is heat welded to the housing. look for damages.
If it seems okay, take a small rubbertube that fits the small nozzle next to the ink outlet. blow into it gently.
if theres air coming out somewhere or the plastic film is broken:
Fix it with some strong tape or replace the cartridge.
Epson Stylus Pro... | Answered on Oct 30, 2012
Take a look at the service manual, I think you'll find a solution there..
http://www.file-upload.net/download-6754855/Epson_Stylus_pro_10000-10000CF.pdf.html
Tip
Epson Stylus Pro 10000 Windows 7 x64 compatible? YES!
Follow instructions under this link. It applies for Vista and for Windows 7 x64 as well.
http://www.fixya.com/support/r1932531-epson_stylus_pro_vista_x64_compatible
Tried it and it works fine. It will for you too!
Good Luck!
on Apr 01, 2012 | Epson Stylus Pro 10000CF InkJet...
Old ink loses some of its intensity after about 8 months.
heat/light seems to destroy some of the depth in the ink's shade. i would be completely replacing the cartridges with fresh ones. Constant cleaning uses up so much ink and the casettes will need replacing too often. This raises the cost of your prints.
Epson Stylus Pro... | Answered on May 09, 2010
hi,
this service message just warns you that the print head temperature is not normal. just give it some time to get to room temperature and then continue printing. if the problem persists, try troubleshooting the printer or test print to check the condition of the printer.
cheers
Epson Stylus Pro... | Answered on Jul 26, 2009
code 45 is lost connection:
so plug the USB cable to another USB-port on the printer and restart it with unplugging the electric cable behind. plug it in again and put the printer to "on"
- most probably then it will see the computer again
Code 45 Currently this hardware device is not connected to the computer epson-printer-error-codes-wutfveiel3ypko01ydor435x-4-0.jpg
Epson Stylus... | Answered on Jul 25, 2020
Google (Epson)(model)(manual) without parens and proceed as directed.
Epson Stylus... | Answered on Aug 25, 2019
Epson Stylus Pro 10000CF InkJet Printer Logo
28 questions posted
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
please solve error code 0001001b when
  • Office Equipment & Supplies
