Mainly this complaint occurs due to the usage of non quality of ink. Use fotonic lyson ink for brother inkjet machines, and periodically (once in a week) clean its print head until the test print found OK.Mainly this complaint occurs due to the usage of non quality of ink. Use fotonic lyson ink for brother inkjet machines, and periodically (once in a week) clean its print head until the test print found OK.
You can't post conmments that contain an email address.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
The head needs to be manually cleaned, gently. If you are using the printer's cleaning function you are using a lot of expensive ink. The head must be absolutely dry before returning it to the printer. If you can't see a way to easily remove the head, don't attempt it.
You may have blocked the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer thanreplace the print head.
