GE JES735WJ Microwave Oven Logo
Posted on Jun 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 721.80012401 Accidentally ran the microwave empty for about 5 mins, now it won't heat up.
Anonymous
Level 3:
  • GE Master 6,771 Answers
  • Posted on Jun 24, 2012
Anonymous
GE Master
Level 3:
Answers
6771
Questions
0
Helped
1779456
Points
21413
Chances are the thermal fuse is gone that protects the magnetron. Unplug microwave, remove top, [several screws] look over to the keypad and slightly to the left, you should see round fuse mounted on the inner chassis at the top, change with the same size and rating, if all goes well the microwave oven should function.
3 Related Answers
Anonymous
  • 65 Answers
  • Posted on Sep 29, 2011
SOURCE: when you put something in
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Anonymous
  • 3 Answers
  • Posted on May 18, 2012
SOURCE: Microwave won't heat
Sounds like the magnetron has failed. :(
Anonymous
  • Posted on Jun 30, 2011
SOURCE: Problem with the GE Spacemaker (JVM1640SJ)
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
3answers
Power went off on my microwave when I accidentally ran it empty for 7 mins. Today my husband tried it and it seems OK, is it safe to use again? Thanks
If you are not sure in ANY way about using this microwave BUY a new one. Simple as that!!
As long there where no sparks, strange noises or strange smells you should be OK to use it. Most modern microwaves have safety electronics built in that can act as a safety switch.
You can buy 'Plug In' adapters that are designed as a safety circuit breaker. Try searching for "Plug through RCD adapter". These 'Trip' if there is a power surge stopping the power to the item plugged into it. I have one for when I use big power tools.
3answers
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
I ran my micro oven for 60 mins. empty. what happens to oven.
When that happens, the magnetron overheats, which can damage or destroy it.
Only a new magnetron can fix this.
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
My microwave is not heating up.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.,
8helpful
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Kenmore Microwave won't heat.
your problem might be more than a fuse chech the magnetron
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
