Green light on PSU is on and stays on while connected to the unit. Battery compartment is empty as it came without a battery and absolutely no power is getting to the laptop.
SOURCE: dell d620 will not go into charge mode
This is usually caused by a bad battery. Sounds like both batteries are not working properly. They may still hold some charge, but they are wearing out. After all, they are batteries, and bateries wear out. Keep in mind that some batteries are better than others, even though they may be the same brand, some will hold a charge longer, and some wear out faster. I'm on my second new battery in a year and a half on my Dell, the first held a great charge but wore out after approx 8 months, the one I'm using now still charges fine but only last about an hour and 15 mins.
SOURCE: Dell C400 Laptop Battery not charging
Go into the battery properties and check if the battery is charging. If it says it is, then test it, use the battery to see if it really is charging, they will sometimes give a false reading. If it's not charging, then check the power supply with an ohm meter for the proper output. If this all checks good, but the battery isn't charging, then I'm afraid you have a failed power management system on the motherboard. The power management system controls the charging along with other power related aspects of the machine. If the power management system has failed, then unfortunately, you will have to replace the motherboard in order to fix it.
SOURCE: I have a Dell D600 (PP05L), its not powering up no
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
SOURCE: Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
SOURCE: dell latitude 100L will not start
Couldnt tell you if its going to solve your problem but you can get a cheaper replacement rechargeable battery here - Dell 100l battery, also good for the inspriron 1100 and 5100 range
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
