A pink or red tint indicated that florescent back light bulbs that light up the monitor are going out. When they start to die they out out red or pink light instead of white light like they should. They bulbs are replaceable but not easy for someone not familiar with this type of repair. Parts would run about $30 plus shipping and are available online but it may not be worth the repair on the monitor due to age.
SOURCE: monitor intermittently goes dark and will not come on
check you monitor cable or replce it. tahnk you..
SOURCE: Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
SOURCE: Monitor has developed a permanent dark turquoise hue.
Did you ever try the original monitor on another machine. If the new monitor is displaying the same symptoms as the old one then your video card is the culprit.
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
