1 Insert a Bluetooth USB adapter into the USB port.
Bluetooth Dongle Connected appears on the display.
Note: A Bluetooth adapter is not included with the printer.
2 From the printer control panel, press Setup.
3 Press the up or down arrow button to scroll to Bluetooth Setup, and then press OK.
4 Press the up or down arrow button to scroll to Security Level, and then press OK.
5 Press the up or down arrow button to select the security level, and then press OK.
• Select Low to allow Bluetooth devices to connect and send print jobs to your printer without requiring users to enter a pass key.
• Select High to require users to enter a four-digit numeric pass key on the Bluetooth device before connecting
and sending print jobs to the printer.
6 The Bluetooth Pass Key menu opens on the operator panel display if you set the security level to High. Use the keypad to enter your four-digit pass key, and then press OK.
SOURCE: How do I stow Lexmark Impact S305 Control Panel?
find a tight plastic locking clip on the underside of the control panel. It may be at the top middle edge on the underside. Give it a very firm upwards press and it should unlock the control panel section.
SOURCE: I need ink refill instructions for Lexmark Impact
Only the Lexmark 100A and 100XLA are refillable.
Click
http://www.refillinstructions.com/Lexmark/L21.htm
for instructions.
SOURCE: i to updated firmware as
if you can...please return your old firmware version and please don't listen to any official Tech support because they care only for taking your money:(
...P.S. Please by yourself a new LASER printer and stop using this kind of "INK SHITs)
pifonski
SOURCE: Lexmark Impact S305 printer continues to jam paper
Clean the rollers with alchohol solutions
SOURCE: how to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
