I have only watched a handfull of movies in this machine, but suddenly it does not even attempt to load the DVD. The device does not spin or seem to recognize that a movie is even installed. This DVD player has an on/off switch in the back and I have tried turning it off and on and messing with different options using the power button and the on and off switch together with no success.
SOURCE: My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
SOURCE: movie does not play
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
SOURCE: Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
SOURCE: Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
SOURCE: player says "no disc"
Hi Thomas!
You may try installing the latest Firmware update from the link given below:
http://www.esupport.sony.com/US/perl/swu-download.pl?upd_id=4704&mdl=BDPS300
Please read all information thoroughly before downloading and installing the file.
If the issue persists then try performing the following troubleshooting steps:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1001161
If the issue persists even after performing all the above steps then service will be required.
