Front panel ''on'' switch works fine, Motor turns on ok, but DW will not start the cycle. Front LED panel says '95' minutes to wait. I can change the wait number to 0 hr, but then it resets to 95.
The Model number is SHU5314UC / UO6. Don't know if the 0 is alphabet or number.The Model number is SHU5314UC / UO6. Don't know if the 0 is alphabet or number.
You can't post conmments that contain an email address.
Hi. I will try to help you.
If what you saying is right, after you hit start. And after some time the dw should indicate a error. I need that error code to be able to help you.
Kind regards
Geir
Technical service enginer @ Bosch Siemens appliances
Here is what I found that makes my bosch dishwasher come on. It has the same problems as the OP. I pick the cycle I want press start. The DW will sound like it's trying to drain. I let it run that cycle which takes about 30 seconds. It then starts another cycle that sounds different from the first and when it stops I turn the DW off and then back on, it resets and then it starts the wash cycle. I've done this twice and it has worked both times. I do not know what is causing this but it's better then what I had to do to get it to reset.
The dw was not quite running. It does pause between cycles. The power scrub cycle means that you had the machine on the longest of all cycle choices. There's almost always a light and a normal cycle. The pots and pans cycle is a power scrub option. Yes all the lights would be on until they switched to a different part of the cycle. Do you have a DRYING light? That would be the one to look for as far as the dw being finished. :)
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump. It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck! Please report back what you find, OK?
Begin at your sink drain that the dishwasher drain hose connects to. Disconnect the hose and check both directions for anything plugging the connection.
Make sure the drain hose has not become "kinked"
(After you have emptied the water from the dishwasher) remove the lower spray arm and the filter in the sump area. Look for obstructions and remove all debris. Rinse the filter thoroughly and reassemble.
If you dishwasher has a timer on the front of the dishwasher that you can manually turn, start a quick cycle with no DW soap and empty.
Allow the water to run in for several seconds and then manually (slowly, gently) turn the timer knob until the DW should begin draining the DW. Listen closely for the sound of the pump motor running.Is water properly draining out of the dishwasher into the drain?
After you have done these things, please post back here and we can take the next steps. OK?
On a Bosch dw, it has a light sensor to sense soil in the water.. if the control feels that the water going through the sensor is not clean/ or clean it will add or minus time..one thing you can do is make sure that your drain line from dw to sink drain is cleared of debris.. also, make sure you clean the filter at bottom of dw and make sure its reinstall correctly if you haven't already do so.. if your dw finish the cycle and come out clean, then the time on your dw is fine,, but if it don't finish and come out dirty.. then, it could be something other, but don't know til I get the full details on problem.. help this will do it for ya.. good luck.. mike
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
when facing the dw pull it out from under counter and on the left side there is a panel held on with 2 screws. take that off and under there are the float switches for the overflow. those switches is what causes the pump to run all the time but do nothing else.
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
