20 Most Recent Bosch 24 in. SHX46A05UC Built-In Dishwasher Questions & Answers
Unlikely to be a level problem. Remove the filter and two screws holding the cover over the wash motor impeller from inside the wash tank - check for something jamming the impeller, like bits of broken glass or fragments of bone, fruit pips etc.
If not that, check basics - water supply, drain hose, filters clear, not syphoning empty, etc.
Bosch 24 in.... | Answered on Feb 04, 2018
the control module has be changed. you can go to thermador .com you can order it from them
Bosch 24 in.... | Answered on Oct 13, 2016
Try unpluggin the dishwasher, waiting 15 to 30 seconds, and then plugging it back in. Otherwise, are any lights flashing, and if so, which ones?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Bosch 24 in.... | Answered on Mar 23, 2015
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course. Good Luck.
Bosch 24 in.... | Answered on Jan 26, 2015
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Bosch 24 in.... | Answered on May 08, 2014
The fact your machine gives off an odour and a slow cycle seems to point to a blocked pump, Disconnect the machine from the main power supply, Remove the back and you will find the pump located at the bottom of the machine, Remove the large hose by squeezing together the retaining clip and you should find it is clogged. Clean all filters within the machine and it should clear the odour and help the machine to run better.
Bosch 24 in.... | Answered on Sep 18, 2013
sounds like the electronic switch usually a Thyristor is not switching when you push the eco button, You could try disconnecting the the machine from the mains then push the buttong in and out a few times to see if the push button has a bit of dust on the contacts..
Dishwashers Logo
63 questions posted
Top Bosch Dishwashers Experts
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Marvin
Marvin
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch shx46a05uc 14 will not shut off
  • Dishwashers
