Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
CLIFF RASBERRY Posted on May 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MAKING ICE TOO SLOW - Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
Jason Kennidy
Level 3:
  • Maytag Master 1,344 Answers
  • Posted on May 31, 2012
Jason Kennidy
Maytag Master
Level 3:
Answers
1344
Questions
0
Helped
370266
Points
4021
A lot of times, the reason ice production slows down is because the freezer isn't cold enough, usually because the freon level of the machine is low. Sounds weird, but even though the freezer is below 32 degrees F, which is freezing, the ice maker requires the temperature be below 10 to function properly. Another cause for the temperature not being cold enough is if the coils are dirty and ther machine is passing the heat to the machine itself
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Ice Maker very slow to make ice. In weeks time, with minimal use, ice hasn't covered the agitator.
Mine doesn't but they do warn that low water pressure will slow down the cube maker.
Scotsman has become very slow in making ice
I would try cleaning the unit, plus if there is a inline water filter I would replace it
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
2answers
Ice maker working very slow , it's still making ice every once in a while, but very slow
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
00
Kenmore side by side model #59432 is making ice very slow
Is the freezer cold enough? Should be close to 10 degrees
, lift the cut off arm and let it drop to see if it will start. It may not be making the switch to continue the ice making cycle.
2answers
Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Slow Ice maker
How much ice does it make per day?
There are several things that affect ice making capability, such as -
1) How often the doors are opened
2) Leaky door gaskets
3) Bad ice mold thermostat
4) Light in refrigerator does not go off when doors are closed (easy to test).
FrigidAire Side By Side Slow IceMaker
there is no way to speed up the ice production, factory set only way to produse mor os depending on age of refig might have an "extra ice" button on display. even thats atemporary fix and probly speed up by 20--30 min
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
