Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Check to make sure that sensor is plugged in good at the sensor end and the logic board end. The printer uses that sensor to tell it that the paper has exited the fuser correctly, if it does not get a signal within a certain time frame it will give a paper jam error and stop printing. The sensor itself may be broken or the little plastic piece that you can see that is called a flag may be jammed so that it does not move to show paper movement. How far does the flag stick out? It should be about 1/8 inch out in the paper path, if less than that the flag is broken off and will need to be replaced. I hope this helps. If you need more info let me know. If this solves your issue than please rate my solution.
It appears that this means that the printer thinks the output tray (on top of the printer) is full. If it is not, then the signal arm may be out of place. Here is a relevant article.... http://support.lexmark.com/perl/support/support.cgi
