Diagram of proper threading
SOURCE: Birds nests under fabric and thread breaking.
My manual says the needle thread tension is too loose , OR the needle is to fine/heavy for the thread being used.
SOURCE: I need a threading diagram
Hi. Check out: http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Let me know if this helps.
SOURCE: thread on bobbin looping
Sounds like you need to adjust the bobbin casing tension (tighten the little screw on the bobbin case). I would also oil the face of the bobbin casing so that the thread wont snag or tug on it at all.
SOURCE: Kenmore 100 stitch 385 Bobbin thread does not
make sure that you have enough of a tail on your thread, at least 3-4 inches and hold it with your left hand until the needle picks up the thread. I am assuming that you have your bobbin threaded correctly and your needle is inserted with the flat side facing the rear of the machine.
