20 Most Recent Kenmore 11101 Mechanical Sewing Machine Questions & Answers
If your gaskets are bad, the machine will not rotate. Can you move it by hand? If not then have you checked the gasket in the back of machine that comes in contact with the hand wheel? If it is making contact, this is what runs the machine and both the little black gasket and the hand wheel will spin when you rotate by hand. If the hand wheel is free spinning then it may need oiled. If you have a manual, try oiling the complete machine according to manual.
Kenmore 11101... | Answered on Dec 25, 2018
You can PDF this manual at Kenmore.com for $5.95. Hope this helps
Kenmore 11101... | Answered on Mar 14, 2015
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Kenmore 11101... | Answered on Aug 17, 2012
try youtube about lowering the feeddogs
or
check with singer website for a manual
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number
Click search
Kenmore 11101... | Answered on Apr 06, 2012
try pulling the buttonhole lever down before you start sewing
let me know if this helps
Kenmore 11101... | Answered on Apr 07, 2011
Gayle,
In a sewing maching, for the thread not to bunch up, there are two thread tension tighteners. One each for the bottom and the top threads. The top thread tensioner is a nut that tightens or loosens the thread tension. The thread passes under this nut. While for the bottom thread it is two screws on the casing for the bobbin. These two screws hold a small strip of metal to the casing and the thread passes under this strip.
To be able to get proper tension on both the threads you have to strike a balance on both the top and the bottom threads. If the difference is not much then you can do with varying only one of them, usually the top one for ease of functioning.
Since you say that the thread is bunching uo on the bobbin side, ie, the bottom, means that the top thread is too tight and must be loosened. You cant do it in the first go. It may take you a few attempts to get it correct, so do not loose heart if it is taking time.
All the best.
Kenmore 11101... | Answered on Jan 27, 2011
This may seem like a stupid answer but did you push in the knob. If you were winding bobbins last time you used it you may have forgotten to re-engage the clutch.
Kenmore 11101... | Answered on Jan 14, 2011
I think it has been discontinued. I don't believe it was a very expensive machine to begin with.
If you have one and are looking to resell it you may want to call a sewing machine repair shop in your area, and see if they will buy it off you or if they know where you can sell it. Try checking on ebay to see how much similar models have sold for.
sewusa.com has threading diagrams
Kenmore 11101... | Answered on Dec 31, 2010
Most of the time it is caused by the top threading, Could your thread be old, or tangled? Double check your threading by this little trick, put your tension dial on 3, totally rethread, insert a new needle (flat side facing rear). Then with the presser foot up, pull on the top thead and it should pull smoothly, now put the presser foot down, pull again, it should barely move. This usually seats the thread in the tension discs. Hope this helps.
Kenmore 11101... | Answered on Dec 08, 2010
I have the same machine. Have you tried adjusting the bobbin tension? Use a small screw driver to tighten or loosen the screw on the bobbin case.
Kenmore 11101... | Answered on Nov 23, 2010
It is usually the opposite of what you think, check your bobbin area and make sure that it is in correctly. Also, check your needle, if in doubt, change it.
Kenmore 11101... | Answered on Sep 26, 2010
Try a new needle and make sure that you have a long enough tail to hold when you lower your needle to pick up the thread
Kenmore 11101... | Answered on Sep 13, 2010
Kenmore 11101 Mechanical Sewing Machine Logo
45 questions posted
Top Kenmore Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Sewing Machines
Most Popular Question
singer brillance lower feed dog
  • Sewing Machines
