Engine errors
SOURCE: engine.exe wont run, sea.dll is the problem
Hello!
I also had serious problems with this game recently, but finally a simple software called SwitftShader2.0 solved it. In my case sea.dll wasn't directly involved, but you may gice this solution a try:
Recently I also had a problem with this game. Every time i tryed to start a new game, an error occured, stating, that the engine.exe stopped, and the program exited. After spening all night researching on this topic, i found the solution: you should install SwiftShader 2.0. It is a simple and great program (as far as i know it changes the graphical performance, in order to get the game work).
You can download it from here: http://www.moddb.com/mods/new-horizons/downloads/swiftshader-v20-demo
Having downloaded, sipmply install it to the root folder of the game (in my case it is C:Program filesBethesda SoftworksPirates of the Caribbean)
Note that, there is a "Config" file in this root folder, and using that you can make the graphical settings of the game (resolution, set it to full screen mode, etc.). For some reasons this didn't want to work in my case, but there is an other way of doing these settings: in this root folder you can also find an "engine.ini" file, which can be opened as a .txt file. If opened as .txt, than you can rewrite the data in it in order to make the desired changes (for examlpe you should rewrite "full_screen = 0" to "full_screen = 1", to activate full screen mode. You cn also chage the graphical resolution of the game this way.)
The link i have given to download SwiftShader2.0 is originally created for "New Horison", which is a promising mode for Pirates of the Caribbean. You can also download this full mode, and install all its features -it containis SwiftShader2.0. Installing this mode may also get the game work -but this way you won't be able to play original version of the game . This mode actually contains much more adventure -for example you can choose from about 7 very different charachters to play with! But personally i decided to play without whis mode, because in my system it wasn't performing well.
I hope, this will solve your problems too. /Sorry for spelling mistakes/
