Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Posted by Anthony on
ANURAG MUKHERJEE
  • 40 Answers
Posted on Aug 10, 2009
I install ms office but show error
sometimes software will not install because your computer is not able to handle the program.check to make sure you have enough ram and space and memory on your computer. make sure you have the right software,apple will not work on windows. Delete something you don't need to make room.Use the process of elimination and I'm sure you can install it. make sure its the right version for your os first.
Jun 05, 2014 | Microsoft Office Professional 2007 Full...
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Mxit evo pc
HiYou need to delete mxit and re install..You can get the setup from www.getjar.com
Hope this helpsRegards
Mar 07, 2012 | Cell Phones
I have a question regarding my Saitek x52pro. When I start a flight on FSX my view immediately pans down to the seat of my aircraft and I cant figure out how to get back to looking straight out over the...
There is a conflict within the settings for your 52. Make sure that you change the "look down" key setting in FSX as think the command your stick is sending is conflicting.
Jun 30, 2010 | Saitek (PS28) Joystick, Throttle
Set Up Error Report:AppName:setup.exe
1. Open Windows Explorer.
2. Follow this path C:\\ Program Files \\ Common Files \\ Install Shield locate the sub
folders Engine and IScript.
3. Rename (Right Click and choose "Rename" both folders example: Engineold &
IScriptold.
4. Close out of Windows Explorer and run setup again.
5. Apply the latest update patches from our website www.roxio.com.
www.roxio.com
Mel
Jun 07, 2010 | Roxio Easy CD & DVD Burning
Canon ir3300 error602-003
how to install data in the hardisk of ir 3300 machine. plz say me the full process what is sst and everything
Dec 09, 2009 | Canon Office Equipment & Supplies
I need the code for the mind quiz
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 05, 2009 | Microsoft Windows Vista Ultimate Edition
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
X52 calibration
have the same problem with my X52; cant get the rudder control (twisting control) work fine, but it goes on its own way to the right and can't be calibrated no way. this is my 3rd SAITEK X52 (2 X52PRO, 1 X52), and all I can say is: SAITEK IS THE WORST **** I EVER HAD IN MY LIFE.
Mar 03, 2008 | Saitek (PS28) Joystick, Throttle
Computers & Internet Logo
372 people viewed this question
Ekse
Marvin
Marvin
