Changed psu still the same.should get a blue light on at on switch but nothing.obviously there is power because cpu fans run and then switch off
Make sure you've got everything plugged in to the mother board, especially the cpu fan attached to the heat sink. it's possible it could also be a memory issue, pop out your memory modules and reseat them.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: PACKARD BELL COMPUTER TOWER
Hi, sounds like your hard drive is going/gone flaky... & if so ya gonna haveta get a new hard drive & a Windows Operating System.
Or take it to a good PC repairer, and get a quote and explanation.
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
SOURCE: HP Compaq D530 sff Will not power up
I have the same problem but it seems to be related to the NIC. When I start without the ethernet cable plugged in it's fine, plug in the ethernet cable and the machine stops dead. I can't even start the PC with the cable plugged in.
SOURCE: iMedia B2217 PC: DVD lid flaps down but drive
There should be a little pinhole located under the door on the bottom of the tray. Push a paperclip in the hole to get the tray open. After the tray opens, close it and see if you can open it normally, if not it's broken and needs replacing.
SOURCE: CPU fan turns for a few seconds and stops, pc will
1. First of all Remove dust from your CPU fan and try again if issue has been not resolve
2. Second test your SMPS by the help of Green & Red wire. In case fan is turning properly it mines your SMPS is ok
3. Third & last kindly replace your SMPS For the same.
