Cameras Logo
Posted on May 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SD Card Problems with Vivitar Vivicam 5118!
Okay, so my friend has a Vivitar Vivicam 5118 and it's having issues. First, the memory card is completely empty, second the little wright protection switch is of so the card isn't locked or anything. When she tries to take pictures, the camera says something like, "memory card is full," then after a few seconds it says in red letters, "card error." The camera also freezes from time to time. We tried formatting the card on the computer but when we do that it says that it is unable to be formatted. We've also tried formatting it on the camera and it is also unable to be formatted. What can we do? Is it a problem with the camera or the SD card?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 07, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
427
Points
0
Same issue same model just bought:
- format done as ntfs didn't work .. tried fat didn't also
- SD lock is not on
- formatted using camera went through but still showing memory full
- the only thing worked for 1 time restore default settings but only captured 1 photo then again memory full
- removed memory still showing memory full
what next ,, ?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Vivitar Master 102,366 Answers
  • Posted on May 05, 2012
Vivitar Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444039
Points
622693
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
5 Related Answers
Anonymous
  • 363 Answers
  • Posted on Oct 22, 2007
SOURCE: memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Anonymous
  • Posted on Nov 14, 2007
SOURCE: Memory Card Format Fail
Never format a memory card using windows. Always use the camera to format it.
In genereal though, cards do not need formating before use, the camera will sort this out for you
Anonymous
  • Posted on Dec 19, 2007
SOURCE: polaroid a300 camera is saying sd protected
Well, make sure you have checked the small gray tab on the left side of the sd card. It needs to be in the unlocked position. Too bad for me, because i have the same problem and my sd card isn't locked...
Anonymous
  • 185 Answers
  • Posted on Feb 24, 2008
SOURCE: KODAK EASYSHARE Z710 DIGITAL CAMERA
Hi Tanya
It sounds like something was corrupted when you transferred your pictures to the computer.
If you have all the pictures safely on your computer, it will be ok to reformat the memory card and then just copy and paste the pictures back to the card.
Insert the card in your card reader, go to My Computer, you should be able to see the card as a removable drive. You can click and open it just like a folder and see what is on the card.
I would also back up the pictures to an external drive or dvd so they are extra safe!
Anonymous
  • Posted on Dec 22, 2009
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
How to use New SD card for Vivitar ViviCam 3785
Card is too big. Specs in the manual say
SD memory card (optional) (up to 512MB capacity)
https://www.manualslib.com/manual/336674/Vivitar-Vivicam-3785.html?page=54#manual
Why vivitar 5118 memory full message no photos or videos detected
It is likely that your card has failed. Take it out of the camera, put it in a reader and plug that into your computer. See if you can view there and remove the pictures to your computer hard disk. If you can not see them there but the computer recognizes the card you will need to use recover software to get your pictures back. Once you have everything throw away the card and get a new one. Unfortunately cards to eventually fail. :(
VivaCam S130 What memory card does it take?
The S130 uses SD and SDHC cards, up to 32GB in size.
I need software for my laptop for a vivicam 5118
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
1helpful
My vivicam x024 won't turn on. how do i remove the memory card? will the photos still be on the card if I remove it?
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out.
The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card.
Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
1helpful
2answers
A friend has given me a Vivitar vivicam without SD card. which one do I get? ( no instruction manual )
You can use any SD card up to 2GB in size, or any SDHC card up to 8GB in size.
You can download the manual from
http://vivitar.com/files_products/21/VC5024%20User%20Manual.pdf
I just inserted 4GB Memory card and took only one picture. I keep getting error message "Memory card is full, insert a SD Memory Card to Transfer and take more photos".
http://www.vivitar.com/products/19/ViviCam%205018%20User%20Manual.pdf
Is the manual, and you need to refer to pages 6 and 7.
If you still have problems, you should contact Vivitar support. This should not be a problem since the camera automatically switches to the SD card when inserted.
Problems Saving data to SD card
The only other thing you havent mentioned is wether or not you have formated the card first.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
