I have 97Toyota Rav4, specially in the winter time all doors starts to act weird. Randomly any time any doors get locked and i can not open it. its auto door lock system in the car. just two days ago the day was nice and dry but was bit cold and when i tried to open the car with remote i could not open the passenger side front door. The door lock was not moving at all. After i drove to work when I checked again it was fine.i never had this problem in summer time. any help?
Over time the grease in the locks etc can become frozen and stop movement when its warmed up a bit it will move better, using the key on the doors every now and then helps move this greas about as the central locking wont move these parts only the switches, replacing the grease after a degreasing locking mechanisms inside the door on the rear of the lock should help choose a grease that can handle low temperatures.
SOURCE: passenger door lock jammed
Your door latch assembly may be compromised. It could be rusted, the electric solenoid (if it has one) may be seized. Or the rods from the key are bent. Are you using th key in this door regularly? If not, the tumblers in the lock may be seized. Spray some WD-40 in the lock where the key goes, and jam the key in & out repeatedly, and retry. Remove the door panel & spray the interior of the latch, also. Hope this works for you; or, you are going to need new latches.
SOURCE: Front passenger door lock won't lock/unlock
You need to replace the electric door lock solenoid.The electrical part of the solenoid may be compromised and is not letting the solenoid arm retract or extend to lock/unlock your door.
SOURCE: 1991 Toyota Camry DX - Front Passenger Door Lock won't disengage
Your power door locke solenoid is seized. You will need to replace it. You are going to have to get the entire door panel off, and then reach in to manually pull the solenoid arm to retract the lock mechanism. Then the door will open.
SOURCE: drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
SOURCE: 2002 Toyota RAV4 passenger side floor Water
Hi, we also have a 2002 Toyota Rav4 and developed a leak in the front driver's side of the car. After much research, we discovered that the drain wells from our sun/moon roof were clogged. If you have one of these, I suggest that you open the sun roof and look carefully. You will notice some tiny little holes in front and in the rear of the sun/moon roof tracks. Over time, these become clogged with dust and debris. You need to find a long, sturdy piece of thin wire and run it down the holes. To test if you have properly unclogged these, take a small amount of water and pour it down the holes. You should see water coming out of the drain wells under the car around the rear of the front tires. Hope this helps.
