Heater fails to start at spring pool opening(i.e., heater sat idle all winter)... HP code flashed for about 2 seconds, but has not returned... Digital contreol appears to be working, but no error code since the 2-second HP... heater just will not kick on...
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
SOURCE: ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Thank
you for posting your question here on Fixya.com.
A 'LO' error code
for a Hayward heater is a limit string open error. If the limit string opens
the heater shuts down and goes into lockout. Automatic restart is 2 minutes
after the error condition is corrected and the limit string closes.
The limit string is
a series of switches designed to turn off the heater if air or water
temperatures exceed a safe operating limit.
The problem may be
faulty a switch(es) but is far more likely to be a system condition the
switches are reacting too that needs to be corrected. Low flow of combustion
air due to obstructions around the heater or the vent; low flow of water
through the heater allowing too high a water temp; Poor venting or sooted-over
heat exchanger causing flame rollout; inlet and outlet hose connections
reversed; these are all conditions that should be eliminated if they exist.
If you are not
familiar with these switches or the conditions described you may want to
consider calling in a professional. Hayward can refer you to someone in your
area who is. Call Hayward at 908-351-5400 or try the website locator found here. It is likely to
still be covered under warranty.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated
once your problem is solved!
John
