20 Most Recent Hayward H-series Electronic Gas Pool Heater H400 Questions & Answers
there is no error code 60 in the world of hayward. is there any chance you are seeing bO? if so, that stands for bypass on and the heater is being controlled by a remote controller.
Hayward H-series... | Answered on Jul 26, 2019
heater shows power, I had to replace three mother board according to tec. Still no sign of egniting. All it does is shows code of bd? what is that? do i need to reset something. help prices are killing me.
Hayward H-series... | Answered on Jun 04, 2019
to start with the basics, make sure there is enough water flowing through the system to activate the heater. you can put sand filter in whirlpool or bypass mode. if there is enough flow through the system, make sure the heater isnt on bypass. make sure that the gas supply is turned on at the heater AND at the meter. if your heater has a pilot light, make sure it is lit.
if you still have issues, you will have to get a service company in
Hayward H-series... | Answered on Feb 12, 2019
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Hayward H-series... | Answered on May 18, 2018
Open the main door, locate the 2 white fabric coated wires, they go down towards the base of the heater. This is your igniter, usually a 5/16 nut driver will be the tool you need to remove it.
Hayward H-series... | Answered on Nov 22, 2017
pull off the side panel, the thermistor is located in the header and can be removed by backing out the nut, and then pulling the sensor straight out.
Hayward H-series... | Answered on Sep 04, 2017
Hayward H-series Electronic Gas Pool Heater H400 Logo
172 questions posted
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Hayward Pool & Spa
  • Hayward Pool & Spa
Most Popular Question
code sf h5 comes up
  • Pool & Spa
