ASUS K50IJ-C1 Notebook Logo
badr Posted on Apr 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DELL INSPIRON 1520 backlight or bulb - ASUS K50IJ-C1 Notebook
Larry Ng
Level 3:
Top Expert:
  • ASUS Master 14,606 Answers
  • Posted on Sep 29, 2018
Larry Ng
ASUS Master
Level 3:
Top Expert:
Answers
14606
Questions
0
Helped
3280695
Points
66651
Old post
the OP question is not clear. at all
my guess, he mean is this PC CCLF or LED
answer: CCFL,.
LED began in 2010 year, (large screens first then small last)
the tubes are bad on all now, 99%
inverters are rare fail. 1% based on stats.
why they fail
how to reach them or not. some are impossible to reach damage free.
why not upgrade to 2010 or never monitor and win. big time win.
http://www.pcdied.com/monitors_and_screens/CCFL-H3LL.html
Stacy Mark
Level 2:
Sergeant:
New Friend:
  • ASUS Expert 124 Answers
  • Posted on Jan 24, 2015
Stacy Mark
ASUS Expert
Level 2:
Sergeant:
New Friend:
Answers
124
Questions
0
Helped
43862
Points
525
There is a good chance that the inverted has developed a fault. This is a part within the screen assembly which controls the backlight. If your equipment is under warranty, Dell can sort it out for you. If however it is not, you will find that laptop repair centres will probably charge you quite a lot to fix it
  • 4 more comments
  • Vanita sadfadf
    Vanita sadfadf Sep 18, 2018
    http://121techsupport.co/hp-support-phon...
  • Anonymous Sep 21, 2018
    vanita you are 6 years late. why?
    the correct answer is both.
    the backlamp CCLF tube bulb is dead.
  • Anonymous Sep 22, 2018
    inverter not inverted. "DC to DC inverter"
    the inverter bad is 1%
    the CCFL is 99% failure rates, well documented.
    this old old PC has $20 street value. now.
    its junk, nobody puts new $100 screen in $20 PC
    why ?Econ101,
  • Anonymous Sep 26, 2018
    2018, answers to 2012 post on PC made in year 2007.
    sure the CCFl lamps are bad, all are that old.
    your CCFL tubes are dead
    a kids flash light pointed at the screen
    omg data is there, back lamps are dead.
    1 minute of work, and posted here 100s of times how.
    no need to guess or be helpless buy a flashlight.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
3711
Points
26
Do you need bell laptop components?
Pcpartsltd.com limited is a direct Exporter of high quality notebooks, laptop power adapters, acer laptop batteries , laptop keyboards, laptop Inverters, laptop Hinges, laptop CPU Fan, laptop driver, laptop MotherBoards, Samsung Wall Mount, laptop LCD Bezel/ LCD lid, laptop lcd/led panel and Laptop LCD Video Cable. We are Laptop Parts experts.
Fix ram slot
Couldn't locate documentation on this unit, no 1520 listed. Typically both card slots must be filled and of matching size/speed etc. Good luck.
3helpful
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
I have a dell inspiron 1520. I have had to set my laptop up on a seperate mmonitor as my screen doesn't work properly. If my screen lights up it may last 5 mins before going dark you can see the screen...
At the base of the screen there is a long bulb, looks like a florescent bulb from a scanner, that is connected to a small board just under the to cover near the the monitor itself. You need to replace that small board. You can get it on Ebay or from Dell. Remove the board to get the part number.
My dell inspiron 1520 does not work at all, power
no this is not a defect this would indicate that the power supply has failed on your pc.. look at the back of the unit if the power supply light is amber in color or blinking thne there is your issue.
1helpful
Inspiron 1520-before finishes loading desktop screen goes black..
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
2helpful
I need a new backlight for my Dell Inspiron 1520 Laptop. How much do these cost and where could I get one?
Here is where you should look:
Call Dell Parts at 800-357-3355 (assuming you are calling from the US).
If you are calling from elsewhere, I believe you can find the parts number on the Dell website.
The number I gave you I have used many times to get parts for my Dell clients. They have good service and can give you prices before you order.
Another option is to go on e-Bay and look for the part--you might get lucky and save some money.
1helpful
2answers
Dell 1520 , on start up screen goes black.... top right hand corner of pc is hot. backlight ?invertor?has the screen got a built in ivertor?? then maybe new screen??? help please....
Hi:
The top right corner of your laptop is where the CPU and heatsink/ fan is located. If you can hook up an external monitor to your laptop, you can toggle to it with the function key and the lcd/CRT key. If you get a good display, then you have a bad inverter or possibly the LCD, but you can't do too much more troubleshooting,
Drivers Inspiron 1520
no problema.
ver a este site
support.dell.com
empuje el numero de model
y tambien la systema de opperaccion
sabes?
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
