20 Most Recent ASUS K50IJ-C1 Notebook Questions & Answers
do you need bell laptop components?
Pcpartsltd.com limited is a direct Exporter of high quality notebooks, laptop power adapters, acer laptop batteries , laptop keyboards, laptop Inverters, laptop Hinges, laptop CPU Fan, laptop driver, laptop MotherBoards, Samsung Wall Mount, laptop LCD Bezel/ LCD lid, laptop lcd/led panel and Laptop LCD Video Cable. We are Laptop Parts experts.
ASUS K50IJ-C1... | Answered on Sep 29, 2018
Try the tab key to get back to the sign-in pane.
ASUS K50IJ-C1... | Answered on Jan 10, 2018
The problem may be the power jack in the computer. Replacement requires removing the main board from the computer to remove the broken or worn power jack and solder in a replacement. A competent technician should be able to do this for considerably less money than buying a whole new main board, so don't get taken. The labor charge will be slightly higher than for replacing the main board, but the parts cost should be no more than $10 U. S. (that's with a considerable mark-up; suppliers charge $1 - $5). Sometimes all that is needed is fixing a cracked solder connection to the power jack; if that is the case, it's a nice idea to apply some hot melt glue or other non-corroding non-conductive removable adhesive to the jack to keep it secured to the main board.
ASUS K50IJ-C1... | Answered on Sep 17, 2017
Try starting in safe mode. If things come up, then you may have malware on the system. I use 'SuperAntiSpyware' and find it to be a great remover of malware. It is free. I liked them so much I moved up to the paid version.
Craig
San Diego, CA
ASUS K50IJ-C1... | Answered on Nov 28, 2015
The serial number is usually found at the bottom of the laptop if not it could be under the battery and also you can find at bios setup.
ASUS K50IJ-C1... | Answered on Mar 11, 2015
Click Ctrl and Print Screen same time. Open the Paint program and paste the picuture.
ASUS K50IJ-C1... | Answered on Mar 01, 2015
Press the Pint Screen button on Keyboard. Open Paint, paste picture to paint, save it as JPG, done.
ASUS K50IJ-C1... | Answered on Jan 26, 2015
Firstly, you should take a screenshot of what's on your screen. Then go to your email account and send the screenshot as an attachment. For more details, you can visit here: http://screenshot.net/email-screenshot.html
ASUS K50IJ-C1... | Answered on Oct 13, 2014
PRESS the DEL key on boot up.... you will enter setup. Pending your computer .... it may be F1 or F11.... normally your shown what key to press at boot up (but the manufacturers (hide the on screen messages during boot up) so turn on this feature as well, because you get to see your system boot. Laptop and Notebooks have simple setups whereas more advanced motherboards like Asus give you a full array of options to control your PC.
ASUS K50IJ-C1... | Answered on Aug 21, 2014
Press Shift and END keys (marked PRT SC on keyboard)
ASUS K50IJ-C1... | Answered on Aug 09, 2014
This is not the "Service Manual" but may help you service your machine - http://www.insidemylaptop.com/disassemble-asus-k-series-notebook/. It is instructions on how to take apart your machine and replace parts as needed.
ASUS K50IJ-C1... | Answered on Jul 30, 2014
Could be more specific? Do you want to install Win7 on your ASUS or what?!
ASUS K50IJ-C1... | Answered on Jul 21, 2014
Go to settings - applications / applications manager (or similar) go to 'all' it should be listed, if not search again for the same game, if it is installed already there will be an option to open the application. Hope this helps and makes sense. if not post back
ASUS K50IJ-C1... | Answered on Apr 17, 2014
wen you notebook is prompt push F12 Function then start 4 or 5 wayform to start try start in second partion disk here stay the sotware to install it of catory or go to control panel and go to programs and then desintall many programs you not use and then go to hard disk propieties and then delete all the carpets with the name temp and you have more disk space
ASUS K50IJ-C1... | Answered on Feb 08, 2014
ASUS K50IJ-C1 Notebook Logo
191 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
K ASUS
  • K ASUS
Most Popular Question
onboard memory
  • Computers & Internet
