Question about Dell Inspiron 1420 1501 1520 1521 1525 Power Supply Charger Adapter Hard Drive
Dell inspiron 1520 won't turn on.
Posted by crafty678 on
Brian Sullivan
  • Dell Master
  • 27,725 Answers
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Posted on Oct 08, 2012
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
I have a dell Inspiron 1520, it's older, it says
you haven't inadvertantly pressed the keyboard key that urns wireless off have you?
some older network cards are incompatible with the latest encryption so you could try setting the router up to use wep encryption 64bit instead
Jan 06, 2013 | Computers & Internet
Changing battery motherboard
Gciappa,
Dell Support > Inspiron 1520 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1520/en/sm/index.htm
Click on Coin-Cell Battery in the right hand list.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Suggest lay a soft static free cloth on the table you're working on. Helps prevent scratching the table, and laptop.
Turn the laptop over, Battery Compartment facing away from you.
3) Remove the Memory Compartment Cover,
http://support.dell.com/support/edocs/systems/ins1520/en/om_en/html/about.htm#wp1175774
(Number 2 - memory module/coin-cell battery compartment )
The RTC Battery is that small plastic 'bag', that has a Red and White wire coming out of it, and ending in a small white plug connector.
(Real Time Clock Battery. Term coined now for CMOS Battery )
Replace battery, close cover, reinstall main battery, and AC adapter.
Regards,
joecoolvette
Nov 04, 2012 | Dell Inspiron 1520 Motherboard
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
Inspiron 1520-before finishes loading desktop screen goes black..
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
Solution for ''the power light for dell inspiron 1520 turns on for about 5 seconds and goes out
If there is a yellow light on the front panel, indicates a faulty AC adapter. If you know someone with an Inspiron 1520, test with their adapter.
Jun 13, 2009 | Dell Computers & Internet
Dell batteries.
Its time change ur batteries
Aug 16, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1420 1501 1520 1521 1525 Power Supply Charger Adapter Hard Drive Logo
691 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
