Router no DBBD38983C
SOURCE: my samsung np-r60 model notebook wont connect to the internet.
Easiest thing to try first is updating your wireless drivers.
go to Samsung's support page and find the latest version, download and install.
Let me know if you need any more help.
SOURCE: Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
SOURCE: MSI U120 Netbook Internet Connection Problem?
At times, a netbook or notebook can create multiple duplicate links to the same network. Each one will diminish the strength of the connection by a little bit and you should clean them out so that there is only one.
Also, it makes sense to use the MAC address on the server side, such that only a netbook with your unique MAC address can connect to the wireless connection. It saves energy/strength if that is your only real security stopper, since like fingerprints, there are no such things as duplicate MAC addresses.
Try making those changes you might just find a cleaner, stronger connection to your WiFi at home.
Good Luck,
-a.
SOURCE: I have followed all the instructions on how to
Had the same problem with my Sylvania Netbook I purchased last week. Last night, I stopped by CVS that received a shipment early in the afternoon and purchased another. Powered on to wifi at first and it would not connect on internet. Clicked on little tv, pulled up my preferred connection and entered Network key. Shut down and restarted and it connected onto google!
My original Sylvania Netbook had the same settings in place and still would not connect - so I am returning it today for a refund - it was defective.
SOURCE: My internet will not connect.
Please check in the Network connection whether the Connection status shows Limited/Local only.
If in case the it shows Limited Only, then follow the steps:
1) Unistall Network Driver and restart then Reinstall the Network Driver.
2) Installed Updated Driver from the Manufacture Site. restart.
3) This should resolve the issue. If the connection status show Connected/ Internet. Then Configure the Wireless connection, by accessing the Router. Check the Router configuration and computer's configuration,.
