20 Most Recent
Samsung NF210-A02 Netbook Questions & Answers
SD card does not go all the way in?
Does it connect though?
Some laptops - the card will not go all the way in as they are made for 2 or more different cards to fit inside.
If you push it in as far as you can, does it show up in 'My Computer'??
3/15/2015 7:51:35 PM •
Samsung...
Answered
on Mar 15, 2015
Laptop have LED on but cannot be switch on the system
that means its the time for you to giving the netbook for service at your near by service centre......or...........you can try downloading new linex or microsoft software.................
the link i send you........from any other devices......and create a disc of it then try on your netbook....or.....you can buy a disc of softwares...........best of luck...........................all the best!!!!!!!.....did it have a fall?
Download Ubuntu Ubuntu
3/22/2014 4:47:49 PM •
Samsung...
Answered
on Mar 22, 2014
How to change my desktop
Right click on desktop and choose Personalize from the menu appeared and select your desired background by finding desktop or background tab.
10/28/2013 12:28:25 PM •
Samsung...
Answered
on Oct 28, 2013
How do I connect samsung nf210 netbook to Sharp HDTV
Usually there is a function key comb to turn on external output (VGA out).
So for example hold down fn key and maybe F2. Which may or may not be the function key for your laptop. The particular fn key will have something that looks like two monitors or a rectangle on it.
9/15/2013 7:04:24 PM •
Samsung...
Answered
on Sep 15, 2013
Nf210 corrupted nf110
Pull battery out. Pull power cord. Hold the power button down for 10 seconds.
Put in battery and power, try again.
9/15/2013 6:51:18 PM •
Samsung...
Answered
on Sep 15, 2013
Boot loop
Hi,try pressing the power button and holding it for 10 seconds. Then wait a while. Turn it back on, you may press F12 or other key when the Samsung Logo appears (before Windows Logo) to see the boot options. Choose the one to check for any errors or anything else - Run diagnostics. Then also you may scan your hard drive for any failures.
6/5/2013 9:01:46 AM •
Samsung...
Answered
on Jun 05, 2013
NF210 Will not turn or or indicate rechraging
Sounds like a capacitor may have burned out on the motherboard, and may be related to the power regulator for the battery. The power regulator on laptops is what regulates how/when/if the battery is charged. Either way, your last posting is correct in that the motherboard needs to be replaced to correct a potentially faulty part soldered into the motherboard. If you need further help, reach me via phone at
https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
8/10/2012 6:00:50 PM •
Samsung...
Answered
on Aug 10, 2012
I forgot the login password
Hello.
There is a hidden Administrator account that is created when your operating system is installed. Access that account and then reset your password.
1. Boot your computer and press F8 repeatedly
2. Access Safe Mode
3. Key in "Administrator" in Username, with no password.
4. Go to Control Panel, then User Accounts
5. Select the account you want to reset the password
6. Change the password
Hope this helps.
9/11/2011 5:03:29 AM •
Samsung...
Answered
on Sep 11, 2011
Getting message telling me
operating system
This is usually due to corrupted files on your hard drive or a problem with the cables connecting your hard drive to your computer. Try obtaining a software disc on your operating system and booting from it. This will give you repair options or an option to reinstall. There might also be a button you can press during the BIOS screen that will help repair or reinstall your OS. If this doesn't work, it is a problem inside your computer with the hardware.
7/29/2011 1:14:40 PM •
Samsung...
Answered
on Jul 29, 2011
