Question about Samsung R530 Notebook
I have lost Bios password on my Samsung R530. How can I get it back
Posted by khalidrida20 on
Phillip Thorne
  • 91 Answers
Usually removing the internal battery in a laptop does not remove the BIOS password. However I have just done this on the Samsung R530 and it did remove it.
Remove AC power, remove main battery, turn laptop upside down and remove all screws, push up the little tabs at the top of the keyboard to unclip it and remove ribbon cable from motherboard, disconnect the 4 wire speaker plug and then pry open laptop from the front, pop the plastic lugs in the battery bay and remove the top facia.
Remove the small coin battery and hold the power button for 15 seconds making sure you do not have the AC jack or main battery installed.
Reassemble, turn on and you should be able to press F2 to enter setup.
Please thank if I helped.
Posted on Jul 27, 2012
  • Mohir Alijonov
    Mohir Alijonov Aug 22, 2013
    thank you a lot lot and lot!
  • ghazanfar ali Dec 30, 2013
    thanks bro is very helpfull thanks
Eddie Chen
  • 661 Answers
Disconnect the battery, unplug it, then open it up. There should be a small round battery called the CMOS battery somewhere in there. Pull that out. Then plug your computer in and boot it up without the CMOS battery. It should say password disabled. Turn it off, disconnect it, put it back together, and you're good to go.
Posted on Jan 24, 2011
ECS IBOUZIR WORKSHOP
    New Friend:
Hi! I did both the solution showed above at the same time, I first remove the small coin battery and hold the power button for 15 seconds, then with the battery still removed I pluged my sumsung R530 and boot it up untill I see the Bios screen showing the modifications I did, then shut it up again, reassemble and it's fixed clean and easy thanks to Phillip, Edward and the FixYa Team
Posted on Mar 25, 2013
HOW TO REMOVE BIOS PASWORD
Windows Password Recovery Tool can really help you, get it from:
http://www.windowspasswordsrecovery.com
Aug 13, 2012 | Samsung R530 Notebook
How to reset windows administrator password for samsung r530
You can reset windows administrator password with Windows built-in administrator account:
1. Log on with the guest account on Vista, then right click computer, and choose Management.
2. Expand Local Users and Groups and Users in the console.
3. Right-click Administrator account and select Properties.
4. On the General tab, clear the Account is Disabled check box.
5. Close the console.
Now the super administrator account is successfully enabled. Next, you can easily reset the forgotten admin password from "Start->Control Panel".
If the above method can not help you, you can use Smartkey Windows Password Recovery to help you to reset the password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Jul 25, 2012 | Samsung R530 Notebook
Laptop samsung r530
see my solution posted on other question
May 25, 2012 | Samsung R530 22GHz Intel Core Duo...
I forgot my hdd password and supervisor password
For your unknown Samsung bios supervisor password and Samsung hard drive password go to http://www.unlockbiosrecovery.com/Unlock_Samsung_Bios.php to get your bios master password and http://www.unlockbiosrecovery.com/Unlock_Samsung_HDD.php for your hard drive master password. They guarantee the master passwords they supply to work or your money back. I use them a few times a month doing my work as a laptop tech.
Jul 29, 2011 | Samsung N150 Atom N450...
My brother's samsung r530 wont boot up as it is asking for a password before booting up window 7 what should I do?
That is most likely the BIOS password, the best solution would be to ask your brother for the password so that you can boot to Windows and use it.
Mar 02, 2011 | Samsung R530 Notebook
Forgot the password, how to I get passed this?
if you forget the system pass word. reset by removing battery and putting it back on the laptop motherboard. is that system password or windows?
Jan 17, 2011 | Samsung R530 Notebook
I forgot my password to my samsung R530 notebook how do I reset it?
Download trinity rescue disk from this site:
http://trinityhome.org/Home/index.php?wpid=1&front_id=12
Follow the instructions on how to load it, and then resset or remove your password allowing you access to your computer and files.
Sep 30, 2010 | Samsung R530 Notebook
Samsung R530 Notebook Logo
3,825 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
