SOURCE: HP Scan Jet 3200C scanning problem
I would say the most likely cause of the issue is either that the scanner is no longer functioning or that it is experiencing power issues. Make sure that the scanner is plugged in directly to the wall and not into a surge protector or a power strip. The scanner does not share power well and pulls it in large amounts - when it can't get it it throws little power fits and sometimes will not turn on at all. Try another wall outlet and see if you can get it to power on and do a scan without the yellow strip showing up.
SOURCE: Blue-green background colors in scan with HP 5470c scanner
Uninstall the drivers.
Reinstall the drivers at this link
SOURCE: 64 bit driver for HP 5470c scanner
Dear go to www.hp.com click on support and drivers then enter your product model now you choose your operating system and download driver free.
First install its software or driver only then you should attach your scanner (when your computer demand or required for its attachment).
Good Luck
SOURCE: Scanjet 5470c with WIndows 7?
better download the latest driver for your scanner from the hp's website and while selecting the new driver you have to specify that you are using windows 7 and also specify if it is 32 bit or 64 bit you will get the driver , install it and connect the scanner it will work ..... thats all....
Yes, same problem with my 4470c HP flatbed scanner.
How did you get yours to work?
