I have an early 1970's Panasonic Am-Fm clock radio. The clock is now dead. There are several numbers on the insdie of the case: No 71970, C037117 18 822.
I'm guessing the electric motor is shot. I pulled it out. It's a General Time Corp, Made in the USA motor. Trying to read the numbers on it, half hidden by braces: NW M5A-115 V -60 CY.
Any idea how to find one of these?
I'm guessing, I replace this, oil the gears with some clock oil, put it back together - then I have a real happy next door neighbor (who has had it since she was 12!).
Let me know.
Thanks.
David
[email protected]
SOURCE: How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
SOURCE: Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
SOURCE: I have a Relic airplane clock and I do not know
It's not easy. You're probably better off brining it to the jeweler unless you already have the tools. You'll need a precision screwdriver set. Under the clock there's a tiny screw. Carefully remove that to pop the clock off the front of the plane -- don't strip it. Then get a standard flathead screwdriver to remove the cover behind the clock. Just turn it so that the tabs on the cover appear in the little openings around the edge. It should then fall out. If not, use a tiny screwdriver to remove it.
Under there is the clock. Remove the plastic spacer. You'll see the tiny little battery, which is held in by a tiny metal arm. Move the arm and the spring behind the battery will pop it up a little. Use a tiny screwdriver to carefully remove the battery. The battery is SR626SW.
Have fun putting it back together! Whoever designed this thing is on my s-list.
