Sony BRAVIA  KDL-40XBR3 40 in. LCD HDTV Logo
A
Anonymous Posted on Mar 20, 2012
Sony tv screen replacement model kp-53865,serial # 90000504
1 Related Answer
Jaime Hernandez
  • 2351 Answers
  • Posted on Sep 24, 2008
SOURCE: Need user manual for Sony Big Screen
Click here to download the user's guide.
My Sony big screen rear projection TV model KP=51HW40 produced 2002 screen flashes red then shuts off. We can turn it back on and it will run for 30-60 minutes and then it repeats red flash. Is this
The Problem you are having is a Cathode to Grid Short in the Red CRT,When it Shorts the screen will Go all Bright Red and shut Down,The Best fix Would Be to Replace the Defective CRT (GUN)
Manual
http://esupport.sony.com/US/perl/model-find.pl?mdl=VPL%20CW125&PRODTYPE=33,32,63,71,7,102,26,80,72,44,55,84,74,27,57,61,103,89,10,35,78,48,77,29,50,39,64,41,12,58,52,81,60,73,66,101,45,76,86,62,54,67,70,68,17,2,1,88,100,82,25,28,83,59,69,49,24,104,53,79,42,22,46,13,6,85,36,3,51,9,47,38,4,34,37,43,5
1helpful
Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Tv will not stay on only for 1 min. then turns red and off
Symptoms shows Red Tube is defective and needs replacement.
Please confirm model number with serial to look for Red Tube in stores.
Thank you.
2answers
The user manual that you have requested can be found at http://www.docs.sony.com/release/KP51WS500.PDF
If you have more problems please ask!
Tim Nolan
14helpful
3answers
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
1helpful
Sony KP-51HW40 51 Screen Protector
this tv has three parts to screen , the most outer part is called CONTRAST screen part # 408195411 for the model you gave.This is available @ sony.com (parts&access) Please make sure this what you need and model is correct..Good luck
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
